Ksp Agc?
kg4pbd
I'll be in KY next week and wondering if anyone can tell me if they use AGC (i.e. on a 396) for monitoring KSP.
I'm not an expert on digital but as I undertand it makes a difference if the TX uses AGC or not. I've tried on my last two trips to Lex to monitor and I've had mixed results. Some of that may be due to low signal strength but I'm wondering if it's an AGC issue.
Thanks in advance
Lostcreekkid
Kentucky
I listen to the KSP and I cannot tell any difference with the AGC on or off. I hear the machine gun sound and it is only after the officers transmit. Never hear it when the dispatcher transmits.
KE4ZNR
KE4ZNR@radioreference.com
munfordville said:
what are the freq......ksp post-3
Welcome to RR.com munfordville! You can find all of the KSP frequencies using the database link at the top of the page...then go to Kentucky and under the state listing you will see "State Police"...to help you out the first time around here is the link:
http://www.radioreference.com/modules.php?name=RR&aid=720
Hope this helps!
Marshall KE4ZNR
