ksp
post 11 london post 10Harlan live southeast Kentucky can not pick up Kentucky state police ? can someone please help
ofd8001
Louisville, KY
This is probably better suited to the Kentucky page.
That being said, I'm assuming you are using a BCD 536 scanner. Are you scanning the full database and have entered the correct zip code? Do you have the Law Dispatch and Law Talk Service Type enabled?
(I'm using a 536 and receive all KSP I expect to around the Louisville area - Post 4, 5 and 12 along with the VHF frequencies they use at state fair time).
Bcd536hp yes full database yes zip code yes yes too law Dispatch and law talk service type enabled yes not getting a thing I will get it more time I'm new too this sorry . Thanks for help in will keep trying
ofd8001
Louisville, KY
I'd confirm you have correctly entered the zip code for your area.
Next I'd set the Range (RANG) button to 50.0. That will cast a pretty wide net. From there you can decrease the value such that you hear only the desired "stuff".
