LA CO FD TMAC 13 reprogramming to start June 3 2013
spectr17
CA
Paicoima was first up IIRC.
Some freq changes and firmware update on the Blue & White Motorola XTL 5000s and HHs.
LZJSR
California
One thing that they have started doing recently is using the V-1 through V-5 command channels on VHF repeat for incidents
f40ph
San Bernardino Co, CA
Anyone know how to look up their VHF repeater licenses? I can't seem to find them entering them on the FCC database.
LAflyer
Global DB Admin
SoCal
Db has mostly been updated with TMAC changes.
Very few local frequency changes. Mostly alpha tag naming changes as agencies better align naming conventions.
LBH
LAC V-1 WPVG961
LAC V-2 WPZM774/WPZM775
LAC V-3 WPVG963
LAC V-4 WPVG964
LAC V-5 WPVG968
They are Part 22 (service code CP (VHF/UHF paging)) "channels" that are licensed in a small chunk of spectrum over a designated area. Individual sites within that area and within that spectrum don't need to be listed. Generally speaking, and within reason, you do whatever you like with the spectrum within your service area.
This information pops up with a regular ULS search. I did a geographic search specifying the frequency within Los Angeles County.
spectr17
CA
The VHF system is a voted repeater system. Radio troops are doing field checks on exact coverage. I want to say there are 6 sites but I need to check to be sure.
