Does anyone know where I can get the MotoTrbo Freqs for Lansing General Motors?
Lansing Delta uses Connect Plus.. I just checked a radio.WQTZ382 - Lansing Parts Plant
936.2000
937.0000
WQTP275 - Grand River Assembly
935.1875
935.2125
935.6875
936.1375
936.4500
936.9125
937.1875
937.2375
937.3875
937.4375
None of this is in the DB. If you are able to determine (a) type of system -- Cap+ or Con+, (b) frequencies in use, (c) LCNs -- I beg you to submit your findings to the database so that others can benefit from your sleuthing. Please only submit verified information though.
Thanks!
Mike
Here’s some info I found out. I’m fairly new to trunking.. so I’m learning... Network ID is 395. Site No 13. Repeater 3. RSSI 71. Neighbor List 23,0,0,0,0. I also know of this number 1315057? Which could just be our talk group?
I have the LGR frequencies entered in my scanner, I believe i programmed it as "trunked" as opposed to "conventional", I've heard transmissions but it seems that it only catches on one frequency all the time and doesn't follow much. Maybe I have it programmed in wrong. Any advise?
I am 2 blocks east of Sparrow Hospital and can hear them decently.
The GM facilities in Ingersoll & St Catherines Ontario are also Connect Plus with a network ID of 395. CAMI in Ingersoll is Site 72 I believe.
Uniden BCD325P2. I have no idea what the color codes are for this system, or even if it's a trunking system at all (vs conventional) I would assume it is a trunking system.What type of scanner? If it's a Uniden, you need to determine proper color codes and LCNs. If a GRE/Whistler, you should be able to just throw all of the frequencies in.
Mike
Systems can only be assigned to a single country in the RRDB, which is why they have to remain as two systems.Interesting. I imagine that these should be consolidated:
General Motors (Canada) Trunking System, Multiple Locations, Ontario
General Motors (Canada) Trunking System Profilewww.radioreference.comGeneral Motors (USA) Trunking System, Various, Multi-State
General Motors (USA) Trunking System Profilewww.radioreference.com
But they probably never will be. I see the Canada ones don't have any control channels designated or provide any clue as to whether LCN order on any of the sites are correct. Meh.
Mike
For future reference, the site is part of the existing GM system linked below. Submissions should be made from the existing system's page, not as a new system in the county. I've reassigned your submission so that it'll get where it needs to go.I submitted the freqs, LCN order, and CC for the Fort Wayne, IN GM plant (395-12) on 01/19/2020.
