Larsen 150/450/800 Antenna
Chevyman22360
I recently purchased two of these antennas because of the reviews on this site for this antenna was so good. I have found that the VHF High is really good, but the 450-460 in my findings is really poor. Am wondering if anyone else has found this. I am using these antennas with me GRE PSR 500. Just looking for other opinions on the UHF band.
Thanks.
fineshot1
NJ USA (Republic of NJ)
I'm not saying that you are not experiencing a legitamite problem but before you come that conclusion make certain that your receiver is not being desensed by strong signal overload from a close by paging station or some other source. A lot of these handheld models have very hot receivers and are easily overwelmed especially when a external antenna is used. Have you tried switching back to the oem duck or another indoor antenna to see if the reception improves?
Chevyman22360
That possibly could be the problem, I have not had the overload problem in my area with the UHF band, but I have with the VHF. I will do some more testing. Thanks
