Larsen NMO150/450/800 pieces needed
WeBeCinYa
NC
Hello guys-
I am looking to get a Larsen NMO 150/450/800 mobile antenna for my Pro 668, but I do not know what all I will need for a complete set up. I located antenna, but what magnetic base, coax, and connections do I need? Novice here with antennas, appreciate the help.
Also if anyone has this set up and wants to sell, I have a wanted ad in the classifies.
cmdrwill
So Cali
Avoid the knock-off Tram, Browning, Comet, Diamond and other junk. Not worth the savings.
I appreciate your help! So just to confirm, since my connector is BNC male, all I would need is the following two items?
https://www.theantennafarm.com/cata...0.html?zenid=b6d61bf63316e4599602631398fc7218
http://www.theantennafarm.com/catalog/tram-1233-bnc-1585.html
I agree with the others, avoid Tram and Browning. While they may be fine for the amateur crowd, you are buying a Chinese product. The Tram and Browning names used to mean something back in the 70's when they were USA based companies that made CB gear. The brand names were bought out and now used for Chinese products. When a Chinese company buys a "U.S." brand name, that should tell you something.
If you can get away with 12 feet of coaxial cable, I'd recommend this magnetic mount base instead:
http://www.theantennafarm.com/catalog/larsen-nmommrbnc-4522.html
Larsen is a well established company with an excellent reputation. While it'll cost you a few more bucks, the antenna and base will last decades with a little bit of periodic maintenance. I wouldn't expect decades of use out of a Chinese knockoff.
As much as I dislike magnetic mounts, I have used a few of these with type N connectors for some small base stations at work. Mostly places with a base radio and the mag mount on a file cabinet. Not ideal, but it works.
