Larsen Tri-band antenna
Frankhappyg
Northeast,Ohio
Anyone using this ?
Just tried to screw it on a NMO mount and it’s very tight hard to screw on.
Anyone have the same issues ?
RRR
OFFLINE
USA
Anyone using this ?
Mine was fine, removed the previous (no spring) one and replaced it with the spring base, screwed on just fine for me
Frankhappyg
Northeast,Ohio
Mmm..... no I made sure
it sat probably before I threaded it on. One of the threads actually came off.
Bought a Browning NMO from Amazon. It was a discontinued product only one left so I bought it. They’re going to give me a full refund .
Went ahead and bought a Laird from antenna farm .
Hopefully it works out better than the first junk. Should’ve bought a good one from the get go
Yep, steer clear of the Tram/Browning crap. Not worth the minimal cost savings. The one time I used on of their mounts (someone else bought it and wanted me to install it, it was OK, but the preinstalled connector was a joke.
trentbob
W3BUX- Bucks County, PA
I've had the new tri-band for a while now. Just unscrewed my old Larsen tri-band, put on the large insulator and it screwed right on my existing NMO connection.
Nice performing antenna as was the old Larsen tri-band. This is a much sturdier mount but the antenna appears to be the same.
RRR
OFFLINE
USA
I haven't noticed any receive difference, positive or negative, from the old Laird and the new spring Laird. Glad to have the spring
Frankhappyg
Northeast,Ohio
Works quite well I must say
Frankhappyg
Northeast,Ohio
RRR
OFFLINE
USA
Bummer it doesn't cover the VHF or UHF air bands.
I beg to differ. I constantly receive bases at 30-40 miles out on VHF while travelling. UHF in general, about the same.
It may not be "tuned" exactly for a specific frequency range, but it sure picks them up just fine.
Now I personally wouldn't transmit with a multi-band antenna....
TRAYSCAN
Register GA
I have just purchased a SDS200 and I am looking for a good antenna for it. I have tried numerous antennas and I scan the bands that the Larson Tri-band Antenna is tuned for. At this moment I am using a PCTel standard 18 inch antenna because it has performed the best for me so far with the antennas that I have. Has anyone tried the Larson Tri-band Antenna on a SDS200? If so, how does it perform? Thanks in advance for any advice
clanusb
Northern CA
Alright, I went ahead and bought one. Put it on this morning and ran some tests. Super stout antenna, typical great Larsen quality. I have not ran around town with it yet, but it it currently running in place of my Larsen 2/70B. I am in the middle of the central valley and right off the bat I couldn't really notice a difference with any of the normal repeaters. We will see how simplex operations go. I was getting good distances with my 2/70B.
My set up is the antenna, going to a diplexer, connected to two XTL5000's, one VHF, one UHF R1 high power units. The antenna is mounted center on the roof between the sunroof and 3rd brake light on a crew cab Ford F-250, with another Larsen VHF 1/4 in between the tri-band and brake light (about 17" spacing).
My testing was performed with a Telewave 44A meter. I'm eventually going to bite the bullet and probably get a comet CCA-500 analyzer at some point this year, so I'll sweep it then.
Here are my findings.
Telewave 44A
145.11:
SWR: 1.46
146.520:
SWR: 1.44
151.82:
SWR: 1.3
154.6:
SWR: 1.3
446.00:
SWR: 1.12
462.550:
SWR: 1.12
467.7250:
SWR: 1.12
Hope this helps.
