I have a Larsen Triband NMO150/450/800 which I really like. I heard there were actually two Larsen Triband models, so I did some online research to find out which one I had. Turns out (1) there are actually 4 Larsen Triband models, (2) two of them are designated with “SF” which I believe stands for “Super Flex”, (3) the information on vendor websites is often inaccurate (even the Larsen website has conflicting data), and (4) there really is not much difference between any of the 4 models in regards to VSWR vs Frequency curves. I spent a lot of time doing this so I thought I would share what I learned…
Data according to Pulse-Larsen website:
Data according to online vendors:
I was able to find VSWR Vs Frequency curves for all but the NMO150/450/800 model on the Tessco and Arcadian websites. These are data sheets provided directly from Pulse Larsen. Ironically, the VSWR Vs Frequency curves for the NMO150/450/758 (dated June 11, 2018) and the NMO150/450/800SF (dated September 4, 2020) models appear to be exactly the same. The VSWR Vs Frequency curve for the NMO150/450/758SF (dated January 23, 2020) is slightly different but not by much. All three models appear to have useable frequencies between 150-174, 430-520, and 750-960 MHz according to the graphs regardless of what is listed in the specifications.
PRODUCT NO. | VHF (MHz) | UHF (MHz) | 7/8/9 (MHz) | PEAK GAIN (dBi) | HEIGHT (in) |
NMO150/450/758 | 150-174 | 430-520 | 750-870 | 0/5/4 | 17.8” |
NMO150/450/758SF | 150-174 | 430-520 | 750-870 | 0/5/4 | 17.5” |
NMO150/450/800 | 150-165 | 450-470 | 806-940 | 0/5/4 | 16.5” |
NMO150/450/800SF | 150-165 | 450-470 | 806-960 | 0/5/4 | 17.7” |
- NMO150/450/758 – The Antenna Farm lists the VHF range as 150-165 (instead of 150-174), UHF range as 450-470 (instead of 430-520), gain us “unity” (instead of 0/5/4), and the height as 16.5” (instead of 17.8”).
- NMO150/450/758SF – Arcadian lists the height at 16.5’ (instead of 17.5”).
- NMO150/450/800 – The Antenna Farm lists gain as “unity” (instead of 0/5/4) . The Ham Radio Outlets lists the 7/8/9 range as 806-960 (instead of 806-940) and the height at “approximately 20 inches” (instead of 16.5”). Tessco lists the 7/8/9 range as 806-960 (instead of 806-940) and the gain as 2dBi (instead of 0/5/4).
- NMO150/450/800SF – Both Tessco and Arcadian list the VHF range as 150-174 (instead of 150-165), UHF range as 430-520 (instead of 450-470), and gain at 0/5/5 (instead of 0/5/4). However, they also have a Technical Data Sheet which looks like it came directly from Pulse-Larsen which agrees with the data on the Tessco and Arcadian websites but disagrees with the data on the Pulse-Larsen website.
