Last 100 FCC License Grants
MtnBiker2005
San Diego County, California
#4
Maybe the county for Skagway can be fixed too. It hasn't worked for very long time.
Skagway-Yakutat-Angoon County Alaska - FCC Licenses
https://www.radioreference.com/apps/db/?ctid=87&tab=fcc
Should be ' Skagway–Hoonah–Angoon '
Skagway–Yakutat–Angoon Census Area. After Yakutat was incorporated as a consolidated-city borough on September 22, 1992, it was renamed Skagway–Hoonah–Angoon Census Area; When Skagway followed suit on June 20, 2007, the census area assumed its current name.
https://en.m.wikipedia.org/wiki/Hoonah–Angoon_Census_Area,_Alaska
blantonl
Founder and CEO
Staff member
Shavano Park, TX
#5
So what you are saying is Skagway and Yakutat are actually independent cities, and need to be separated out, correct?
Any then the current county entry needs to be renamed to Hoonah–Angoon
MtnBiker2005
#6
Use whatever County name the main FCC database is using.
Trying reviewing the FCC search on this page.
The custom FCC data search works for "Skagway-Hoonah-Angoon" or "Skagway" and showing FCC licenses hits.
No hits for Skagway-Yakutat-Angoon. Because it's the old county name.
https://digitalfrequencysearch.com/
County list names
https://digitalfrequencysearch.com/Search/Counties.php
Found some info online...
In Alaska:
Prince of Wales – Outer Ketchikan Census Area was dissolved and distributed into other counties including Ketchikan Gateway Borough, Prince of Wales-Hyder Census Area, and Wrangell City and Borough
Skagway-Hoonah-Angoon Census Area was split into Hoonah-Angoon Census Area and Skagway Municipality
Wrangell-Petersburg Census Area was split into Hoonah-Angoon Census Area, Petersburg Borough, and Skagway Municipality
Wade Hampton Census Area was renamed Kusilvak Census Area
http://www.countyhealthrankings.org...irginia-what-happened-to-the-counties-that-no
https://www.familysearch.org/wiki/en/Alaska_Borough_Creation_Dates_and_Parent_Counties
