I am in Southern Ohio, (Gods Country) and listen to the MARC's system. I upgraded to the latest firmware yesterday and my scanner has not spoken a word since. Any suggestions?
Yes, I did update both, Firmware and the database, everything down here is MARC's IP, as well as some conventional stuff. I am unable to pick up anything since I did the update.
OK, I had a file from back in Feb. that I had saved, I cleared the scanner, and loaded the old file, and now it is picking up everything in the area. Don't know what I did, but I hope I pay better attention next time. Thank you for the advice.
More than likely the upload file had some radio parameters or settings in it that you or the upgrade knocked off. By reloading, you set them back to where they were when working. Still not sure if you are using favorites list or full database. You should be able to update both now without fear of knocking things off. Then I would give this updated file a save on your PC so the valued setting (whatever it was) is now stored as part of your updated files.
