Latest Help Vers. For HP-1 ?
BOBRR
Boston, MA
#1
Hello,
Have a HomePatrol-1
Getting going again, so trying to update everything.
I now have, and am presumably using:
Sentinel vers. 2.03
and on the unit's screen:
Firmware 2.06
Database 11/27/2016
So all good so far. Right ?
But the Help vers comes up in the unit as 12/07/2011
2011 !!
Is there a newer one ?
If so, how do I find it, and how do I download to the HP-1 ?
Thanks for help,
Bob
fxdscon
#2
Hello,
Have a HomePatrol-1
Sentinel vers. 2.03
Firmware 2.06
Database 11/27/2016
2011 !!
Thanks for help,
Bob
That is the newest version of the HP-1 help files. There have been some small differences in the general operation of the scanner since production began, but not much has changed in the physical operation of the scanner since it was introduced.
If a firmware update significantly changed anything with how the scanner is operated, and if Uniden published a corresponding new help file, it would be written to the card during the usual update process.
Smaller changes in firmware worth mentioning can usually be found here:
http://info.uniden.com/twiki/bin/view/HomePatrol/HomePatrolUpdates
or within UPMan's postings in the forums.
hiegtx
Dallas, TX
#3
HomePatrolUpdates < HomePatrol < TWiki
In addition to what fxdscon noted, there is an "Easier to Read" manual for the HP-1/HP-2 series and their version of Sentinel:
Easier to Read HomePatrol-1/HP-2 Digitall Scanner and Sentinel Manual
