LCD Screen Brightness Adjustment
bob550
Albany County, NY
I am a new G5 owner. I have been attempting to manually adjust the LCD brightness via the Main Menu, Function Settings, LCD Brightness setting. I highlight "Manual" and press select using the "Navigation" button, but it does not allow me to move the brightness adjustment either up or down. I've found that if I repeatedly press select, it will randomly highlight and permit the adjustment. Other than the brightness adjustment, the select (Navigation) button works fine. I realize I can adjust the brightness via the PPS and have done do by that method. Am I doing something wrong?
hakwye8518
Town of Islip, NY
once on the lcd brightness screen use the navigation button and push down to highlight brightness then left for dimmer right for brighter or use the blue triangle for dimmer or the white diamond for brighter
bob550
Albany County, NY
When you say push the navigation button down, you mean toward the 6 o'clock position? That works! It seems you can either push the button toward either the 6 or 12 o'clock position to highlight the brightness control.
JD21960
ILL-annoyed
Once you're in the LCD brightness menu... you have to MOVE the big button DOWNWARD so the green line is where you want it to be. Then it gives you another quick menu to + - add/minus the brightness.
