LCRA & GRE Programming
mikebennett
Sherman, TX
Can anyone with a GRE scanner that monitors the LCRA in the hill country tell me if you have to turn on the "EDACS INVERT" option in order to receive this system?
I'm trying to program for an upcoming trip.
The only EDACS system I monitor up here is ONCOR and it does require that function.
Mike
Sanscanman
N5WRF
Acworth, GA
Hiya Mike,
LCRA is a EDACS STD system not NARROW so you should not even be offered the option to apply the invert with PSREdit or Win500, I'm not sure about doing it manually unless it is under the expert settings in the TSYS menu. Bottom line it is not needed to hear them.
Hope your trip is pleasant
mikebennett
Sherman, TX
Hiya Mike,
I program with ARC500 and that option is available for either STANDARD or NARROW.
Thanks for the info.
