Lebanon County PA. Noob
Hiskid1973
PA
I am interested in getting a scanner and what I would hear. The county has some kind of edacs system.
I set up and SDR sharp and see alot of activity 450-564 MHZ that is mostly digital sounds plus the
trunk tracker on th SDR# goes right to 849 mhz digital sounds. Would I be able to hear any of this
with a Pro 106/HomePatrol scanner. If I can get the SDR/Trunk tracker working would that be able
to hear more? Is it better than buying a scanner separately> Thanks and GBY
Hiskid1973
PA
It is a software defined radio (SDR) receiver made from a cheap tv dongle. Receives from 40mhz thru 1.5 ghz.
