TRX-2: LED Colors Not All There
N6HHR
Cypress, CA
Greetings,
I can't get all the colors that they say are available on the LED. I can get a good green, blue, red and purple. But I can't get anything near a white, yellow, orange or many other colors as indicated on the EZ Scan color palette. Curiously, I get the same LED colors conundrum on my TRX-1 too. Can anything be done? Or should I just be thankful for the colors and flash patterns I do get? Thanks.
73, David, N6HHR
Ubbe
Stockholm, Sweden
If you adjust the LED values in the scanners menu you can then see what the LED are doing and can adjust to the color you want. For some reason there's decimal values and hex values in scanner and EZ-scan so you will have to use a calculator like the Windows one in programmer mode to convert and use in EZ-scan.
/Ubbe
N6HHR
Cypress, CA
Thanks very much you guys. Very helpful. I especially like being able to make the adjustments and see the results immediately right on the radio itself. I'll play with it and see what I can and can't get, color-wise.
73, David, N6HHR
