LED Light
HoDo
Baltimore, Maryland
Is there a way on the PSR-800 to set the LED light to come on when any transmission is received on a scanlist or do you have to set the LED to come on each tgid that is programmed individually.
Bronson24
Frostproof,FL
From what I have seen you have to set Each TGID..
Ed_Seedhouse
Victoria B.C. Canada
Yes, using the control software. just select all the items in your scan group and click on the column to change the LED behaviour. Just click the left column of any line to highliht that line, then hit {Ctrl}{a} and that will highlight them all. Then click on the Backlignt/LED column and any changes you make will apply to all the highlighted items. Easy. fast, no fuss no muss. Don't forget to upload your changes to the scanner.
krokus
Southeastern Michigan
Wirelessly posted (BlackBerry8530/5.0.0.973 Profile/MIDP-2.1 Configuration/CLDC-1.1 VendorID/105)
Bzzt! Wrong answer.
How do you know what that poster has, or has not, seen?
Either way, what he posted was not wrong, as stated in your own post. You merely showed a neophyte a faster way of accomplishing the task.
