FW,
Sure there is a lot of DC in both the pre-storm blanketing of +ions, the streamers themselves, and perhaps thousands of DCV from a connection to a cloud. Considering the cloud-to-ground potential is in the millions of volts, a few hundred or thousand volts of DC protection misses the point from a risk-management prospective. As to streamers and ground-level +ions, there is nowhere to "drain" those pre-storm charges because they cover everything, all surfaces, from earth to several hunded feet above ground. While such ionization tends to equalize across all outdoor surfaces, it can still behave remarkably such as "flash visibly" from sharp-corner objects into air space. I do not know if that gathering of +ion streamers, or the massive energy from nearby-strikes are responsible for exceeding the dielectric value of a disconnected coax, but I have observed carbon-tracks from arcing between the center-conductor and the threaded (shield) connector.
In theory, a DC-grounded antenna could minimize some damage from low-level energy, so I don't want to make it sound useless. Just don't let anyone tell you it (alone) can save the day in a direct or very close attachment from lightning.
As to personal preference in surge arrestors, I think the I.C.E. (Industrial Comnunication Engineers, Ltd) company makes the best protection gear. They use a multi-level defense to incoming surges that includes a static-drain on the center-conductor (yep there's a little DC ground, ha ha), a strong inductor for the next few thousand volts, and finally the gas-tube for as much as any coax connected to it could carry.
It's important to remember that no surge arrestor is built to survive more than the breakdown voltage of the coax it is designed to mate with can carry . Most coax used in our work will be 3/4" hardline/heliax or less, and those breakdown at or less than 8,000V. RG-8 breaks down at less than 6,000V and house wiring breaks down at around 3,000V. Proper shield-grounding of coax before it gets to an arrestor/surge protector further limits what will be delivered to the arrestor even in a direct attachment to the antenna. Thus any properly designed arrestor can do it's job when the requisite bonding and grounding design are in place. Unfortunately the arrestors all work just fine in reverse, which means that they will unwittingly help deliver a whopping several thousand volt surge from your power company's electric lines right through the radios on it's way into your convenient outdoor grounding system. When guys sink a single rod for a rooftop or treetop or other outside antenna, and then forget to bond that ground rod to the AC entrance ground rod, this is beggging for the example just given to happen. It can happen anyway if the bond is too far, or there is no AC surge protection at the AC meter or entrance panel.
Hope this helps.
J
