Line spacing
ofd8001
Louisville, KY
#1
All of a sudden when I write a post, whenever I hit the Enter key, I'm seeing additional blank lines, as if I pressed the Enter key more times than I did. I have to do the preview thing, then go back and delete the extra lines.
Any ideas what is causing this?
W9BU
Lead Wiki Manager
Super Moderator
Brownsburg, Indiana
#2
If you are hitting the Enter key, thus inserting a carriage return/line feed, there's no need to do that unless you are trying to create a new paragraph. The forum software will automatically break your lines to fit the screen. For example, this reply was typed without hitting the Enter key at all.
iMONITOR
MACOMB, MI.
#3
This is something new, as it started happening to me for about a week now. I always use carriage return and never had it create double spaces between paragraphs before. Kind of a pain.
I under understand you are saying you've enabled automatic word wrap? The only problem with that is if you want to format text differently.
ofd8001
Louisville, KY
#4
I usually try to use multiple paragraphs. That is to keep separate thoughts apart and avoid confusing a reader.
While I hit the Enter key twice, once to end the paragraph a second to add a line space, it looks like an additional line space was added (as in one more carriage return than I actually typed). There have been no changes to my computer that I'm aware of that would cause this to be happening. Just like iMonitor said, its been a week or so since this began.
W9BU
Lead Wiki Manager
Super Moderator
Brownsburg, Indiana
#5
I
have
no
issues
with
double
lines.
The Enter key was pressed once between each word above. The result is a single line. It could be something on the RR end. It could be something with your browser.
