DODGEIT said:
Does anyone know if there is a list of CTCSS tones that are used in a geographic area? EXAMPLE: If I wanted to find the CTCSS tones for a city in Florida how would I go about finding out this information? I am a member of a fire department that works in VHF High Band and I have a radio that works in this band. I was told I could use it if I could get it to work. This department is a small department and they don't have this information that they know of. The company doing there work won't give up that information for free. They would program the radio if I brought it to them. $50.00 bench fee and then whatever time it takes to program it. I told them no thanks. I can program it myself if I had the information. Any help out there would be appreciated. Unfortunatley the information is'nt available at radioreference.com
There is no real geographical use of tones per area. Just about all tones are likely used anywhere. As was said, you could get a scanner that decodes tones. You also might want to try a web search using Google or something for a site with local frequency information on it. Since scanners now have CTCSS/CDCSS capabilities, many web sites now include this information. Don't bother with an FCC search - they don't have CTCSS/CDCSS info. You could also ask the person who gave you permission for the info. If he doesn't know, see if he can help you get it. Any good radio shop who deals in your product in your area should already have the info you need, or be able to get it and program your radio for you. There should be more than just one.
As a last resort, if it's CTCSS, there are 32 standard tones (38 standard based on the expanded list). You could program the frequency in yourself and try it. If you have 16 channels, program the same frequency in each with a different tone and try them. You should get it in 2 program sessions - 3 at the maximum. If it's CDCSS, there are over 100 possible codes. Still, it's free if you can program it yourself. Just save your original configuration so you can upload it again when you find the correct tone.
You also can try asking on a state or local based scanner email list. Try searching YahooGroups for one. I'm assuming you already asked in the state forum on RR.
Joe M.
