Listen to a Moto. Type II smartnet
sjcscanner
a trunking scanner...almost all trunking scanner do that system i think...
n2mdk
Ames, IA
You should check the database to see if the system is only analog, digital or both. Then you know whether you need a digital trunking scanner or an analog one.
Stick0413
Hopewell, VA
As others have said... Check the system in the database and see if its digital or not... Then we could help a little more.
DaveH
Ottawa, Ont.
Confused1234 said:
How do I listen to a Motorola Type II Smartnet system? What kind of scanner do I need?
You definitely need a trunking scanner capable of Moto (all that I know
of are), but which ones work for you depends on the frequency band
of the system. Most older trunk-trackers work or 850 or 850/900MHz
systems, but if you are talking VHF/UHF, it rules out some of the
older ones (although it's a bit of a relative term). Let us know...
Dave
Confused1234
Mandeville, LA
The system is analog...
The system is analog. freq---- Primary 935.22500
936.22500
937.22500
938.22500
939.22500
What scanner will work?
How do I program the scanner?
loumaag
Silent Key - Aug 2014
Katy, TX
936.22500
937.22500
938.22500
939.22500
Almost any current or recent trunking scanner (except the Pro-2051). How to program depends on what you get. It would still help if you linked the system page (from the DB) here.
If you are talking about the LA Superdome, you need to be close. Very close, as it was designed for use in and around the facility only. Much more than across Poydras or the Expressway and it won't be much good.
Confused1234
Mandeville, LA
I am talking about...
I am talking about the superdome. I will be in the dome for an event this Friday and I wanted to listen to the audio visual channel.
derrek_lee_25
iowa
will my pro95 work im going to cedar rapids iowa sunday and the moto type 2 smartnet is what that city uses
loumaag
Katy, TX
Yes it will work. You won't hear much of interest since the "good" channels are all P25 CAI.
With that I am closing this thread. It is in the wrong forum to begin with and the above is OT from the initial post anyway.
