Live Radio Communications Audio on the wiki updated that I have added.
Hi Everyone,
I updated the live radio communications audio under Live Scanners and Live Tunable Receivers below.
Live Scanners - http://wiki.radioreference.com/index.php/Live_Scanners
IRLP Amateur Radio Audio Feeds
Reflector 9201 Spanish
DB0VOX Node 5515 and Echolink DB0VOX-R
IT9DLN Menfi - ITALY Node 5971
Other Amateur Radio Audio Feeds and Websites
CA - Sylmar K6HOG Flying-Pig.net: Contractors Peak 445.040 MHz repeater - K6HOG, K6HOG FLYING-PIG.NET: Contractors Peak - Sylmar, CA 445.040 MHz repeater - K6HOG
Three Dog Repeater Group - Repeater Linking System Audio - Southwest And Central Virginia
World Wide Audio Feeds New
- Germany - DB 0 ZU - Amateur Radio DH0GMA
Live Tunable Receivers - http://wiki.radioreference.com/index.php/Live_Tunable_Receivers#U._S._A._Free_Online_Receiver.27s
Shortwave Log Online Receivers RCSweb Youngsville, NC USA FM06, Raleigh, North Carolina USA Drake R8A/R8B,
MA - N3FI Online Receiver in Hughesville, Maryland
MS - Scan Massachusetts Cape Cod's Web Controlled Receiver
NC - Youngsville, NC USA FM06 Ten-Tec RX-320/321
NC - Raleigh, North Carolina USA Drake R8A/R8B
World Wide Online Tuner Receivers New
Germany - Berlin, Germany DL7PZ Online Reciver
Japan - Uwajima, Japan Uwajima, Japan Javaradio
New Zealand - Wellington, New Zealand Webserver Controlled Radio Receivers below AOR AR-7030 QTH, AOR AR-8200 Mk3 QTH and FRG-100/DRM QTH
AOR AR-7030 QTH
AOR AR-8200 Mk3 QTH
FRG-100/DRM QTH
Netherlands - Netherlands, Zwolle Receiver Ten-Tec RX320. (100kHz - 30 MHz | AM, CW, LSB, USB)
Saudia Arabia - Manfred Kohl Manfred Kohl, 7Z1UG / DK2UG
cg
Connecticut
just a minor correction
MD is Maryland, MA is Massachusetts, and MS is Mississippi.
cg
