dynamitedjs
Topcop has just started his part time live feed of Richmond, Henrico and Chesterfield Fire and EMS. Here are the directions to tune in:
Listeners need to download and install this easy to use program and then log into the IBN server to connect to the live feed (more on all of this below). In addition there are also other live feeds on the IBN server that you can also try if you'd like, all live, and all FREE. There's even a CHAT feature that lets you message other listeners while you listen, to discuss the action. How cool is that?
Now, that all said, here's what you need to do to listen to the feed:
(We suggest you print these instructions for convenience & future reference)
1) Go to http://www.goteamspeak.com/downloads.php and download the Team Speak Client program.
2) Double click the downloaded file to install the player.
3) Once installed, start the program
4) Click on 'CONNECTION' on the main menu bar
5) Click on 'QUICK CONNECT'
6) Enter www.incidentbroadcast.com:8767 as the Server Address
7) Enter a name as your Nickname (can be any name, this name will show to other listeners on the site)
8) Leave both the Login Name & Password BLANK
9) Click the 'CONNECT' button
10) Once you connect a voice will say "Link Engaged"
11) Once connected, the VERY FIRST thing you need to do is click on 'SELF' on the menu bar
12) Then choose 'Register with Server'
13) Enter your Nickname in the 'Login Name' box'
14) Enter your Password in the 'Password' box
15) Enter your Password again in the 'Password Check' box (be careful of typos!)
16) Click the 'Register' button
17) Click on 'CONNECTION' on the main menu bar
18) Click on 'DISCONNECT' (do NOT close Team Speak)
19) Click on 'CONNECTION' on the main menu bar
20) This time click on 'CONNECT' (NOT Quick Connect), which you will use from now on to log on.
21) RIGHT click inside the large white window on the left of the 'Local Address book' tab.
22) Click on 'Add Server'
23) Enter IBN Live Scanner Feeds and then press the ENTER key.
24) Now, fill in all of the rest of the information and select the options
24.a) Change Default Channel to VA - Richmond Area Fire/EMS
25) Click the 'CONNECT' button
26) Once you connect a voice will say "Link Engaged", and a list of Channels will appear in the left panel
27) Scroll down the list and find VA - Richmond Area Fire/EMS
28) DOUBLE-click on this listing
29) You are now listening to the LIVE feed of the City of Richmond, Counties of Henrico and Chesterfields Fire/EMS Traffic and hearing all of the action!!
30) Once connected, read the info page (top right window) for more details, & don't forget about the chat feature.
31) ENJOY, and tell your friends! (please refer them to this page for the instructions)
32) Remember! Use the CONNECT option for logging on from now on, NOT the Quick Connect Option.
