Livingston County Police
Nowhere, USA
#2
I can't tell you for sure, seeing how im in Erie County, I can't get a signal because its so far away, however, last year, Livingston County switched over to a P25 Phase II Trunked Radio System. The DB still shows that as a frequency, however, what its use for is unknown to me. The new TRS has a lot of users on it, and it would appear to me from looking at it, that everyone has made the switch over.
https://www.radioreference.com/apps/db/?sid=9093
#3
Up to two days ago they used it as a analog repeater of their p2 police channel I only have a p1 receiver so now Im out of luck
hfd26
#4
My guess is that they did stop using it since a new trunk tower was put up in dansville. I believe the analog frequently was for portabLe since they had poor coverage in the valley.
