fbx22 said:
Im using the BCD996T.I just cant figure out why its telling me Im hearing troopers on towers located in sitka, juneau, etc. Maybe the frequencies there are the same as towers in palmer, anchorage, or seward for instance and it happens to use juneau?
What's probably happening is that you programmed ALL the control channel frequencies and their corresponding labels as listed in the database. And if you happen to be in Anchorage and the radio tunes to 154.8000, that's the N. Anchorage site 135 and NOT the Sitka site "518", regardless of what the label says in this case.
The radio only looks at the frequencies and NOT their labels. During the scanning cycle if it comes across one of the channels with 154.8000 in it and it's active locally, it'll tune to it even if it's the one labeled Sitka.
The frequencies for this system get re-used when they're far apart enough from each other i.e. frequencies assigned to Anchorage might also be used in Juneau or Sitka since there's enough separation to not interfere with each other. So the best way to find out which tower you're really tuned to, is to Hold on the control channel and see what tower number is displayed and correlate that with the site numbers on the database i.e. 154.8000 in the Anchorage area will most likely show you a site # of 135 so you'll know is the N. Anchorage one.
Bottom line is: You should only program the frequencies and their corresponding labels that are within the Borough you live in. Because otherwise you'll have unnecesary repeats in your banks and the probability to see the wrong labels displayed for the local frequencies.
