Logging In
REDave
Metro Area MN
Why do we need to log into the database and forums separately? It would seem to me that once logged into the site you could navigate both parts with one log-in.
ScanDaBands
State Line
That only happens to me if I haven't been on in a while.....................
kd4bas
Monitoring, Hanging Out, & --mn-@v@-mn-- you.
Morganfield, (Union Co) KY
I have had to since I joined the site. No big deal, I would like to see it changed if Lindsay could manage it though.
loumaag
Silent Key - Aug 2014
Katy, TX
hoser147 said:
You shouldnt have to something must be messed up..............Hoser
Actually the main part of the site, the forums, and the Wiki are all seperate systems and all require seperate logging in; however, you must use the same login information at all three. Somewhere down the road they will all be tied together, but not yet.
loumaag
Katy, TX
Well...yeah.
If you don't log out, you don't have to login (unless the site goes through a software update or you erase your cookies.)
loumaag i have trouble logging in ,"password dont match, also when hit my first log in name, the list shows.. with astring of nbrs behind my name i try to get it corrected and i want to continue using my original pasword etc , all i get the at help is that " i want to list anew password help.....
blantonl
Founder and CEO
San Antonio, Whitefish, New Orleans
Folks,
It is the same username and password across all three resources:
1. Portal (general site, databases etc)
2. Forums
3. Wiki
However, you must individually log in to each resource. Typically, once you are logged in, you should stay logged in. In addition, you should be managing your password at the following link:
http://www.radioreference.com/apps/account
If you need to change your password, changing it there will update all 3 systems. You if you need to RESET your password (i.e. you forgot etc), use this link:
http://www.radioreference.com/apps/account/?action=reset
This will also reset your password in all 3 locations.
Both these links are on the home page of the site. If you have a problem resetting or changing your password, head on over to:
http://www.radioreference.com/apps/help/
Thanks!
Lindsay
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
Lindsay I suggest you make this a sticky. It's very likely this will come up again
73 Mike
