Logging Multiple Sites
nickburns
This may very well have been covered before but I cannot find a good answer. Is it possible with Unitrunker to monitor more than one site in a 9600 Smartzone Omnilink system without using more than one receiver? Thanks.
J
Deeke
If you scan two different systems at the same time, you will get alot of corrupted data and false readings for sites that do not exist.
It's best to monitor oneat a time. If you change sites/systems, shut down and restart Unitrunker or disconnect and reconnect the sound input.
The control channel provides very limited information about neighboring sites because there is no reason to provide more. The only way to tell what is happening at another site is to monitor the other site. As Deeke points out - you don't want the radio bouncing back-and-forth between sites - it will confuse the program and make a mess of your channel data.
