Looking for an NMO mount based CB antenna that can withstand high speeds
steve0827
As the title states, I need to find a CB antenna that will connect to an NMO mount that will be able to sustain high vehicle speeds.
Thanks in advance,
Stephen
n9mxq
Belvidere IL
That would be it. 10 meters is 28MHz.. I'm a huge fan of Larsens antennas and have owned several for ham bands and have never been disappointed.
However, I've never owned this particular antenna.
steve0827
Will I be missing out on any channels with that antenna? I'm a noob at this stuff haha
n9mxq
Belvidere IL
No, you would need to tune it properly for the 27MHz band. It should work well once that is done. It will come with all the instructions you'll need
I'll second the Larsen NMO-27. Great antenna and if installed correctly, should have no issues at highway speeds or well above. Be aware that the whip will fold over a bit at speeds and reduce efficiency, but I'd rather do that then a fiberglass antenna that might crack.
n5ims
Thanks in advance,
Stephen
If it helps you descide, the Larsen NMO27 is often what many state police agencies use as the CB antenna on their patrol cars. If it can withstand the speeds they drive, it should do fine for you. Since it's specifically made as a CB antenna it should cover the entire set of frequencies just fine.
steve0827
Are there any antennas which are a little bit shorter? I believe I read that the Larsen NMO27 is 51" tall.
n9mxq
Belvidere IL
I doubt that you would find a shorter one for NMO.. I don't think I've seen many NMO antennas for that band.
KD0TAZ
Kansas
This ^.
You can GET a shorter antenna, but anything shorter than 48-50 inches will work like crap.
Sent from my Galaxy SII using some Tappity Talkity thing.
LtDoc
Oklahoma
First, understand that all mobile HF antennas are compromises. Antenna 'length' is based on frequency wave lengths and in the HF range they are going to be sort of 'big'. A very rough rule of thumb (RROT) is that something on the order of about 1/8 of a wave length is the shortest you can get without a LOT of compromise.
Another bunch of RROT is that 'looks' and performance are not all that compatible, almost direct opposites of each other. Of course, it's a 'mind set', depends on what you think 'looks' good.
Probably the two biggies are cost and what's practical. Practical being the the bigger of the two, sort of. You can ;load' an antenna to make it shorter, but the that loading always is a compromise, maybe not much of one, but still a compromise. Quit compromising when it suits you and still does close to what you wanted.
- 'Doc
gcvaughn
Florida
I have the Larsen NMO-27 mounted on the trunk on my Mercury and get swr readings on channel 19 of 1.4:1. It receives well and I get good reports on transmit with my Uniden Pro-520.
mikepdx
Corbett, OR USA
I only use Larsen antennas for
durability, service life and performance.
The NMO-27 is a great antenna for CB & 10m amateur radio.
