Looking for Center Frequencies
thenewsden
Mechanicsburg, PA
I will be traveling primarily Interstate 81 South from Mechanicsburg, PA into Tennessee. I would like to monitor the center frequencies while enroute. Is there someway to find out what frequencies an aircraft flying the same route would be handed off to along the route? Thanks for any help.
FLRAILMAN
Banned
Orange City, Fl.
PA. to TN. ARTCC handoff freq's
Check the RR database, that should help, it appears to be very accurate. Happy hunting.
FLRAILMAN
thenewsden
Mechanicsburg, PA
Thanks for the info. I was hoping someone had a source where I could find geographically where the individual sectors are located. I had checked out the RR Database but it doesn't give any info to where the sectors are located. I know their names gives clues but I'm not familiar with the area that well.
FLRAILMAN
Banned
Orange City, Fl.
ARTCC freqs.
Also try this site, the webmaster keeps the sector frequencies pretty much up to date. On the upper left corner, click on: Aviation-then-Aviation monitoring-then-ARTCC centers.
Freq Of Nature
FLRAILMAN
adamgirard
Albany, NY
I'm not sure if we are talking about the same thing here but I'll give it a shot.
I have frequencies programmed into my scanner for the Albany, NY area. When the ARTCC frequencies come in, it is only the aircraft talking to the center but NOT the center talking to the aircraft.
Is there any way to listen to what the center is saying to the aircraft or am I just too far away from the center to hear these transmissions? Are they on a separate frequency than what the aircraft uses to talk to the center?
Thank you!
FLRAILMAN
Banned
Orange City, Fl.
ARTCC comms.
If you are in close proximity to an ARTCCs RCO (Remote communications outlet) you will hear the controllers directly, if not, don't worry because the aircraft repeat what the controllers say anyway.
FLRAILMAN
thenewsden
Mechanicsburg, PA
FLRAILMAN
Is there somewhere to find the actual location of the ARTCC's RCO?
FLRAILMAN
Banned
Orange City, Fl.
ARTCC RCO freq's PA to TN via I-81
I have one more ARTCC frequency chart besides the two Bucko & I gave you earlier: Military Comms Monitoring. HF VHF UHF just click on ARTCC Center Freqs. on the left side of the home page so now you have three ARTCC charts to work with. You will be traveling through the following ARTCCs on I-81 (KZNY) New York Center, (KZDC) Washington Center, & (KZTL) Atlanta Center, this is presuming that your trip ends where I-81 ends in Jefferson County Tennessee & not further west toward (KZME) Memphis Center. I included a town & city finder website that covers each state you will be traveling through so you can match any locations on the list that match the specific ARTCC RCO charts locations. Good luck.
FLRAILMAN
Towns in USA, States, List of Counties, Points of Interest, Businesses, Lodging, History, News, Real Estate, Tourism
thenewsden
Mechanicsburg, PA
I understand that there are lists that contain names that sometimes give clues as to where the transmitter is located. I was hoping to get a little more specific, such as coordinates or something. That way I would be able to narrow down a little better how my reception is based on where the transmitter I am hearing is located. Thanks again for all of your help and comments on this.
crayon
RF Cartography Ninja
36°33'01.2"N 98°56'40.1"W
RCO's do not service ARTCC's. That would be an RCAG.
Outlets are also given different names according to the type of facility they serve. If an outlet serves an AFSS/FSS, it is called a RCO. If an outlet serves a terminal facility (control tower or approach control ), it is called a Remote Transmitter/Receiver (RTR). If an outlet serves an Air Route Traffic Control Center (ARTCC), it is called a Remote Communications Air/Ground (RCAG) facility. GCOs can serve any type of facility, in fact they often serve two facilities simultaneously according to the number of clicks keyed on the microphone.
FAI AFSS - Overview of Services
FLRAILMAN
Banned
Orange City, Fl.
ARTCC RCO coordinates
I called the FAA & they said that there is a CD that they have available that should fit your needs, I hope you are taking a laptop. Here goes:
FAA Charting Office
Aeronautical information Services Division
1-866-295-8236 EXT: 35442
ARTCC Facilities & Frequency CD
They said if you need it immediately it might be available at:
Albany County Airport Authority
Million Air Albany
Albany Airport
518-242-2226
FLRAILMAN
(PS) Crayon is right the ARTCCs remote outlets are called (RCAGs) sorry about that.
