looking for HF comms aircraft
oxnard ca
a few years back i would listen to aircraft on about 8MHZ.
i had a old analog tuner then now i have a ditigal read out.
anyone know where to start? i may be tuning to fast between 8 to 9mhz.
i am looking for a starting point.
thank you
DW
SoCal.
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
That's a pretty thin description, but I suspect you were listening to MWARA stations. The links for that, and more, are here (anything in blue is a link...)
HF Aeronautical Communications - The RadioReference Wiki
Don't tune so fast. Take your time - and understand a bit about how propagation is affecting you. You'll quickly learn what freqs might be active vs. ones that are likely to be closed to your location.
best regards...Mike
brandon
SoCal
San Francisco Radio uses 8843 kHz USB. You can also hear them on 5547, 5574, 6673, 10057, 11282 and 13354 in the Central East Pacific. They are all used in a daily basis and will have excellent signals into Oxnard.
oxnard ca
thank you guys, that was the freqs. i was looking for.
the 8843 was hit as soon as i put it in and in SSB.
thank you again
DW
SoCal.
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
Yep, that's one of the MWARA SP freqs as shown on the HF Underground map...best regards..Mike
AirScan
In the North Pacific I've noticed San Francisco using 8951 and 5628 recently.
