Looking new scanner gratiot clinton countys
Hello all I am looking for a new scanner that I can use to listen to gratiot co pd and fire also mmr ambulance for gratiot also on clinton county listen to ambulance, fd, and pd even thou I know clinton co uses a edacs but I hear some of there traffiac on ingham co rr feed under 19p911 tag. Is there any scanner that I could use to update my current rr feed at all? I will admit I am not up to the newer scanners or mpscs but wanting to learn and possibly of adding more to my feed since I been getting some emails asking if I could provide this for the listeners. Thank u upfront for your help.
Sent from my phone using Tapatalk 2- Please excuse any errors.
bailagent67
Michigan
I wish I could help you, I have a BCD996T I paid $600 for back in 06. I'm in Isabella County and it not going very well for me. Someone on here can you help you a lot more than me. If I was in your shoes right now, I would get a $150 scanner from Ebay / Craiglist and just try that. I cant, because I already have this one. Good luck though,
Ronaldski
MI DB Admin
Bay City MI
Gratiot- Gratiot County, Michigan (MI) Scanner Frequencies and Radio Frequency Reference
You'll be able to pickup everything with the exception of the fire departments radios which are mototbo that no scanner can get. bailagent67 is in Isabella that so much of it is mototrbo. I can pickup the 911 calls going out on 154.16 here in bay city on the outside antenna, but I also can hear the replies in mototrbo noise on 155.130 from the fire department personnel that are mototrbo.
See - http://forums.radioreference.com/michigan-radio-discussion-forum/282296-gratiot-county-fire-new-mototrbo-system-starts-1-21-14-a.html
Gratiot pd, jail, alma/st. Louis, animal control & MMR are digital on mpscs while the rest are on regular vhf.
All the rest are non digital.
Clinton is http://www.radioreference.com/apps/db/?sid=473
Showing as EDACS but that radio setup is being dropped for support by Harris corporation. So I'd expect Clinton to be looking to something else as is Consumers Energy is as well which also uses EDACS.
Find a digital radio is all,
Pro 96, Pro 2096,Pro 197, or Pro 106
Uniden model BCD396T, BCD996T, BCD396XT, BCD996XT,436HP,536HP or Home Patrol scanner.
GRE model 500, 600
GRE model 500, 600
Thank you for your reply
