Looking to build a dipole for 455 Mhz
Manchester UK
#1
Hi am looking to build a Dipole for 455 Mhz just to receive I have been looking around but can't find much on this maybe some body could help me out looking at 6 Element or a half wave dipole in mm would be great with the spacing.
M3FUE
Manchester UK
#4
You are talking about two different types of antenna. Do you want a beam or a dipole? A dipole would be very simple to construct. A beam would be a little more difficult.
Hi there thanks for coming back to me so fast I would like to build a simple dipole just not sure about the length from left to right or the dipole ----------- mm [ ] mm ------------- not sure what size to cut the metal poles for 455 Mhz 455.000 Mhz up to 456.000.
Tom Sherratt
M3FUE
ipfd320
Banned
W.Babylon N.Y. 11704
#5
i just picked up a tram 4150 uhf-adjustible antenna base version...49.00 bucks from PALMETTO ANTENNAS.com-----....he has alot of antenna,s in stock plus cables-patch cords and a few other goodies
i am happy to say i finally am able to hit our repeater 5x5 compared to the hand held with stock antenna a big improvement...recieve is definately 10 times better also
