BITT211
between UNIDEN BCD536HP OR WHISTLER TRX2 - WHICH WOULD YOU PICK FOR THE BEST , CONVENTIONAL P25 DIGITAL RECEPTION , thanks for reply
i would get something that does not depend on a sd card to operate and get corrupted easily.
I'm new to scanners, actually haven't bought one yet. Was waiting for the SDS200 to be available and I will likely let a little time pass to see if there are issues right off the bat before I do buy it. Do these scanners require a card to operate? Or does the card just provide certain other capabilities?I think that only matters if you are rough on an sd card, doing recordings, taking it in and out all the time, etc. I don't do any recording with my scanners, and I program them all with sd card inside the radio, and I have never yet had to replace a corrupted sd card. I have a friend who does nothing BUT record with his scanners, and he has to replace his cards periodically. Just what I have observed.
JD
kf4anc
Yes, you need the sd card. Just think, this little card puts the entire US/Canada frequency database into your radio, along with your personal programming and preferences/settings. Always backed up with the programming software (Sentinel). As fxdscon stated, if you use Sentinel, you will always have a complete backup of your radio's programming. Write To Scanner, and you are back up in minutes.
JD
kf4anc
You can send in a 1095/1098 Scanner to Whistler for an Legacy Upgrade and gain DMR as well as be able to use the TRX EZ Scan software. If you send in a TRX Scanner , you can get NXDN for FREE.
