That's strange Cos other people say loops out do wire antennas o
Anyone who says an active loop, like the Wellbrook or Pixel antennas (both very good antennas), will always outperform a wire antenna is incorrect. Period. What kind of wire antenna, how is it installed, what location, what frequency range? All “wire” antennas are not the same, nor do they all perform the same.
In some instances, for example in an urban setting with its potentially high QRM and small areas for antennas, for HF listening an active loop will often outperform a sub optimal wire antenna installation (as opposed to an optimized wire installation). This probably describes the conditions of the majority of listeners today, moderate to high QRM urban environment, limited space for antennas. Add to this the fact that making a wire antenna work well under these circumstances can require quite a bit of effort and installing an active loop is rather simple. This leads to a lot of people thinking that an active loop is “better”, and it can be, from their understanding, their specific conditions, and the level of effort they are willing to, or can, put into the antenna installation.
But if you are in a moderate to low QRM location, or take the time to find ways to mitigate the QRM, and have room for larger antennas or put real effort into making a limited space wire antennas work, you can find many wire antenna configurations that exceed the abilities of active loop antennas.
The active loop is a quick and easy answer that can perform surprisingly well for very little installation effort. It has certain specific advantages, as do most antenna types. But that does not mean it is the “best possible” antenna.
Remember that wire antennas are just antennas, they don’t have to be made of wire, that can be just a convenient form factor for many people to install. A dipole is a dipole, be it made of wire or aluminum tubing. You can make wire beams with significant gain, or you can build them of rigid metal, the rigid structure ones are easier to turn on a rotor. Multi wavelength Beverage antennas, curtain arrays, and Rhombics are all antennas with controlled radiation patterns and, again, significant gain, and antennas typically built of “wire”.
Professional listening facilities intent on optimum performance, unless space or mobility is an issue, do not typically use loop antennas, and even less often use active loops. And yet many of them use arrays of “wire” antennas.
For HF listening (and transmitting, although I typically listen much more than I transmit) I currently have 12 different wire antennas (this number changes over time, wire antennas are easy to experiment with). I also have several different “rigid” antennas, like beams, elevated ground plane antennas, rotatable dipoles, etc. And I have a couple of loops, including the Wellbrook ALA1530+.
I end up using the loops to find direction on stations at frequencies below about 6500 kHz (the bottom frequency end of my other directional and rotatable antennas) and to listen at LW/MW freqs. I also use the loops to track down noise sources when they show up. And I use other antennas for almost everything else, because for almost every signal I can find another antenna (often wire) that receives it better (higher signal to noise ratio) than one of the loops.
T!
