So I made the change and am sad to say it still drops audio. Started at 10 30 am and right now there is no audio.
Task man shows 1132mb of ram in use and 19 on the cpu.
10:31:19.704 INFO i.g.d.icon.IconModel - loading icons file [C:\Users\Preferred Customer\SDRTrunk\settings\icons.xml] [11MB/124MB 9%]
10:31:19.710 INFO i.g.d.icon.IconModel - Icons file not found at [C:\Users\Preferred Customer\SDRTrunk\settings\icons.xml] [11MB/124MB 9%]
10:31:19.898 INFO i.g.d.log.ApplicationLog - Application Log File: C:\Users\Preferred Customer\SDRTrunk\logs\sdrtrunk_app.log [19MB/124MB 15%]
10:31:19.934 INFO i.g.d.log.ApplicationLog - SDRTrunk Version : 0.5.0-alpha6 [22MB/124MB 18%]
10:31:19.934 INFO i.g.d.log.ApplicationLog - Gradle Version : Gradle 6.3 [22MB/124MB 18%]
10:31:19.934 INFO i.g.d.log.ApplicationLog - Build Timestamp : 2020-10-26T04:29:57.816-0400 [22MB/124MB 18%]
10:31:19.934 INFO i.g.d.log.ApplicationLog - Build-JDK : 15 (BellSoft 15+36 [22MB/124MB 18%]
10:31:19.935 INFO i.g.d.log.ApplicationLog - Build OS : Linux (amd64 4.4.0-193-generic [22MB/124MB 18%]
10:31:19.935 INFO i.g.d.log.ApplicationLog - [22MB/124MB 18%]
10:31:19.935 INFO i.g.d.log.ApplicationLog - ******************************************************************* [22MB/124MB 18%]
10:31:19.936 INFO i.g.d.log.ApplicationLog - **** sdrtrunk: a trunked radio and digital decoding application *** [22MB/124MB 18%]
10:31:19.936 INFO i.g.d.log.ApplicationLog - **** website:
DSheirer/sdrtrunk *** [22MB/124MB 18%]
10:31:19.936 INFO i.g.d.log.ApplicationLog - ******************************************************************* [22MB/124MB 18%]
10:31:19.937 INFO i.g.d.log.ApplicationLog - Memory Logging Format: [Used/Allocated PercentUsed%] [22MB/124MB 18%]
10:31:19.937 INFO i.g.d.log.ApplicationLog - Host OS Name: Windows 10 [22MB/124MB 18%]
10:31:19.937 INFO i.g.d.log.ApplicationLog - Host OS Arch: amd64 [22MB/124MB 18%]
10:31:19.937 INFO i.g.d.log.ApplicationLog - Host OS Version: 10.0 [22MB/124MB 18%]
10:31:19.937 INFO i.g.d.log.ApplicationLog - Host CPU Cores: 8 [22MB/124MB 18%]
10:31:19.937 INFO i.g.d.log.ApplicationLog - Host Max Java Memory: 4 GB [23MB/124MB 18%]
10:31:19.938 INFO i.g.d.log.ApplicationLog - Storage Directories: [23MB/124MB 18%]
10:31:19.938 INFO i.g.d.log.ApplicationLog - Application Root: C:\Users\Preferred Customer\SDRTrunk [23MB/124MB 18%]
10:31:19.938 INFO i.g.d.log.ApplicationLog - Application Log: C:\Users\Preferred Customer\SDRTrunk\logs [23MB/124MB 18%]
10:31:19.940 INFO i.g.d.log.ApplicationLog - Event Log: C:\Users\Preferred Customer\SDRTrunk\event_logs [23MB/124MB 18%]
10:31:19.940 INFO i.g.d.log.ApplicationLog - Playlist: C:\Users\Preferred Customer\SDRTrunk\playlist [23MB/124MB 18%]
10:31:19.940 INFO i.g.d.log.ApplicationLog - Recordings: C:\Users\Preferred Customer\SDRTrunk\recordings [23MB/124MB 18%]
10:31:19.949 INFO i.g.d.util.ThreadPool - Application thread pool created with [8] threads [5MB/124MB 4%]
10:31:19.949 INFO i.g.dsheirer.gui.SDRTrunk - Home path: C:\Users\Preferred Customer\SDRTrunk [5MB/124MB 4%]
10:31:19.955 INFO i.g.d.p.SystemProperties - SystemProperties - loaded [C:\Users\Preferred Customer\SDRTrunk\SDRTrunk.properties] [5MB/124MB 4%]
10:31:19.955 INFO i.g.d.p.SystemProperties - SystemProperties - application properties loaded [C:\Users\Preferred Customer\SDRTrunk\SDRTrunk.properties] [5MB/124MB 4%]
10:31:19.973 INFO i.g.d.s.SettingsManager - SettingsManager - loading settings file [C:\Users\Preferred Customer\SDRTrunk\settings\settings.xml] [6MB/124MB 4%]
10:31:20.179 INFO i.g.d.s.r.RecordingSourceManager - RecordingSourceManager - discovered [0] recording configurations [10MB/27MB 39%]
10:31:20.266 INFO i.g.d.s.t.TunerManager - LibUSB API Version: 16777478 [12MB/27MB 45%]
10:31:20.266 INFO i.g.d.s.t.TunerManager - LibUSB Version: 1.0.22.11312 [12MB/27MB 45%]
10:31:20.419 INFO i.g.d.s.t.TunerManager - discovered [10] attached USB devices [12MB/27MB 45%]
10:31:20.438 INFO i.g.d.s.t.TunerManager - USB Bus [1] Device [8087:8008] Hub Device [12MB/27MB 45%]
10:31:20.439 INFO i.g.d.s.t.TunerManager - USB Bus [3] Device [8087:8000] Hub Device [12MB/27MB 45%]
10:31:22.094 INFO i.g.d.s.t.TunerManager - USB Bus [2] Device [0BDA:2838] LOADED: RTL2832 SDR/R820T 00000001 Max Rate:38400000 bps [13MB/27MB 51%]
10:31:22.095 INFO i.g.d.s.t.TunerManager - USB Bus [2] Device [8086:8C31] Hub Device [13MB/27MB 51%]
10:31:22.096 INFO i.g.d.s.t.TunerManager - USB Bus [2] Device [413C:2111] Unknown Device - Class 0 [13MB/27MB 51%]
10:31:22.097 INFO i.g.d.s.t.TunerManager - USB Bus [3] Device [8086:8C26] Hub Device [13MB/27MB 51%]
10:31:22.098 INFO i.g.d.s.t.TunerManager - USB Bus [2] Device [0764:0501] Unknown Device - Class 0 [13MB/27MB 51%]
10:31:22.135 INFO i.g.d.s.t.TunerManager - USB Bus [2] Device [1D50:60A1] LOADED: Airspy 04A464C8-342F810B Max Rate:320000000 bps [14MB/27MB 52%]
10:31:22.161 INFO i.g.d.s.t.TunerManager - USB Bus [1] Device [8086:8C2D] Hub Device [14MB/27MB 54%]
10:31:22.196 INFO i.g.d.s.t.TunerManager - USB Bus [2] Device [046D:C52F] Unknown Device - Class 0 [14MB/27MB 54%]
10:31:22.209 INFO i.g.d.s.t.TunerManager - ------------------------------------------------------------- [14MB/27MB 54%]
10:31:22.209 INFO i.g.d.s.t.TunerManager - USB Bus - Potential Maximum Data Rates [14MB/27MB 54%]
10:31:22.213 INFO i.g.d.s.t.TunerManager - USB Bus [2] Rate [358400000] bits per second *** WARNING *** [14MB/27MB 54%]
10:31:22.214 WARN i.g.d.s.t.TunerManager -
* WARNING: the combined data rates of tuner(s) on USB bus(es) above can potentially saturate or exceed
* the maximum USB 2.0 data rate of 480 Mbps. This can cause data loss and severely impact decoding
* performance resulting in missed calls and stuttering audio. Recommend moving tuner(s) to other
* USB ports/buses to better balance data rates across available USB buses.
****************************************************************************************************** [14MB/27MB 54%]
10:31:23.108 INFO i.g.d.p.PlaylistManager - Loading playlist [C:\Users\Preferred Customer\SDRTrunk\playlist\default.xml] [14MB/30MB 47%]
10:31:23.258 INFO i.g.dsheirer.gui.SDRTrunk - starting main application gui [20MB/30MB 68%]
10:32:05.032 ERROR i.g.d.g.p.s.StreamingEditor - Unable to refresh broadcastify stream configuration(s) [55MB/89MB 62%]
10:32:12.913 INFO i.g.d.a.c.m.JmbeAudioModule - Loading JMBE library from [C:\Users\Preferred Customer\SDRTrunk\jmbe\jmbe-1.0.7b.jar] [107MB/182MB 58%]
10:32:12.924 INFO i.g.d.a.c.m.JmbeAudioModule - JMBE audio conversion library loaded: JMBE Audio Conversion Library v1.0.6 [107MB/182MB 59%]
10:32:12.924 INFO i.g.d.a.c.m.ImbeAudioModule - JMBE audio conversion library IMBE CODEC successfully loaded - P25-1 audio will be available [107MB/182MB 59%]
10:32:12.941 INFO i.g.d.d.f.c.ComplexPolyphaseChannelizerM2 - Sample Rate [6000000.0] providing [240] channels at [25000.0] Hz each [108MB/182MB 59%]
10:32:12.974 INFO i.g.d.s.t.u.USBMasterProcessor - Starting USB master processor thread [117MB/182MB 64%]
10:32:13.805 INFO i.g.d.s.t.u.USBMasterProcessor - Stopping USB master processor thread [258MB/312MB 82%]
10:32:14.841 INFO i.g.d.s.t.u.USBMasterProcessor - Starting USB master processor thread [259MB/312MB 83%]
10:32:15.929 INFO i.g.d.s.t.u.USBMasterProcessor - Stopping USB master processor thread [204MB/312MB 65%]
10:32:16.947 INFO i.g.d.s.t.u.USBMasterProcessor - Starting USB master processor thread [205MB/312MB 65%]
10:32:18.054 INFO i.g.d.s.t.u.USBMasterProcessor - Stopping USB master processor thread [153MB/312MB 49%]
10:32:19.077 INFO i.g.d.s.t.u.USBMasterProcessor - Starting USB master processor thread [153MB/312MB 49%]
10:32:19.745 INFO i.g.d.d.f.c.ComplexPolyphaseChannelizerM2 - Sample Rate [2400000.0] providing [96] channels at [25000.0] Hz each [166MB/312MB 53%]
10:33:21.862 INFO i.g.d.s.t.FrequencyErrorCorrectionManager - Auto-Correcting Tuner PPM to [0.5] [246MB/375MB 65%]
10:33:45.589 INFO i.g.d.s.t.u.USBMasterProcessor - Stopping USB master processor thread [242MB/375MB 64%]
10:33:52.935 INFO i.g.d.s.t.u.USBMasterProcessor - Starting USB master processor thread [245MB/375MB 65%]
10:33:53.793 INFO i.g.d.s.t.u.USBMasterProcessor - Stopping USB master processor thread [232MB/375MB 61%]
10:33:54.822 INFO i.g.d.s.t.u.USBMasterProcessor - Starting USB master processor thread [233MB/375MB 62%]
10:33:55.919 INFO i.g.d.s.t.u.USBMasterProcessor - Stopping USB master processor thread [294MB/375MB 78%]
10:33:56.929 INFO i.g.d.s.t.u.USBMasterProcessor - Starting USB master processor thread [295MB/375MB 78%]
10:33:58.043 INFO i.g.d.s.t.u.USBMasterProcessor - Stopping USB master processor thread [193MB/375MB 51%]
10:33:59.057 INFO i.g.d.s.t.u.USBMasterProcessor - Starting USB master processor thread [193MB/375MB 51%]
10:34:34.116 INFO i.g.d.m.d.p.P25TrafficChannelManager - Stopping traffic channel: Suffolk County (Project 25)_Site 4_TRAFFIC_29 [206MB/375MB 55%]
10:34:34.119 INFO i.g.d.m.d.p.P25TrafficChannelManager - Stopping traffic channel: Suffolk County (Project 25)_Site 4_TRAFFIC_27 [210MB/375MB 56%]
10:34:34.143 INFO i.g.d.m.d.p.P25TrafficChannelManager - Stopping traffic channel: Suffolk County (Project 25)_Site 4_TRAFFIC_30 [243MB/375MB 64%]
10:34:34.162 INFO i.g.d.s.t.u.USBMasterProcessor - Stopping USB master processor thread [245MB/375MB 65%]
10:34:39.825 INFO i.g.d.s.t.u.USBMasterProcessor - Starting USB master processor thread [247MB/375MB 66%]
10:34:40.683 INFO i.g.d.s.t.u.USBMasterProcessor - Stopping USB master processor thread [260MB/375MB 69%]
10:34:41.704 INFO i.g.d.s.t.u.USBMasterProcessor - Starting USB master processor thread [260MB/375MB 69%]
10:34:42.809 INFO i.g.d.s.t.u.USBMasterProcessor - Stopping USB master processor thread [206MB/375MB 55%]
10:34:43.822 INFO i.g.d.s.t.u.USBMasterProcessor - Starting USB master processor thread [207MB/375MB 55%]
10:34:44.934 INFO i.g.d.s.t.u.USBMasterProcessor - Stopping USB master processor thread [320MB/375MB 85%]
10:34:45.963 INFO i.g.d.s.t.u.USBMasterProcessor - Starting USB master processor thread [320MB/375MB 85%]
10:35:23.360 INFO i.g.d.s.t.u.USBMasterProcessor - Stopping USB master processor thread [321MB/375MB 85%]
10:35:26.529 INFO i.g.d.s.t.u.USBMasterProcessor - Starting USB master processor thread [327MB/375MB 87%]
10:35:26.937 INFO i.g.d.s.t.u.USBMasterProcessor - Stopping USB master processor thread [298MB/375MB 79%]
10:35:27.952 INFO i.g.d.s.t.u.USBMasterProcessor - Starting USB master processor thread [299MB/375MB 79%]
10:35:28.537 INFO i.g.d.s.t.u.USBMasterProcessor - Stopping USB master processor thread [154MB/375MB 41%]
10:35:29.599 INFO i.g.d.s.t.u.USBMasterProcessor - Starting USB master processor thread [155MB/375MB 41%]
10:35:30.141 INFO i.g.d.s.t.u.USBMasterProcessor - Stopping USB master processor thread [184MB/375MB 49%]
10:35:31.208 INFO i.g.d.s.t.u.USBMasterProcessor - Starting USB master processor thread [185MB/375MB 49%]
10:41:58.708 INFO i.g.d.a.c.m.AmbeAudioModule - AMBE CODEC successfully loaded - P25-2/DMR/NXDN audio will be available [451MB/525MB 86%]
