Lost Hartford Edacs last night
Chris0381
I have 6 trunked systems in my scanner and for some reason the Hartford Edacs system stopped working all of the sudden. I'm wondering if others had anyproblem as the frequencies did come in in non-trunking mode on the pro-97.
I tried re-uploading the win-97 file and setting to trunking mode but with no avail.
Looks like I have some trouble shooting to do. Most likely I'll initialize the scanner and use a new win-97 FILE to re-enter only the Hartford trunk and try from scrtach.
Chris0381
I believe I found out what was wrong. It looks like I may have somehow selected sort by frequency in win-97 causing the logical channels to rearrange. We need a function sort by logical channel now to get them back in order. Time for some cutting and pasting. I guess I should label each LC with a letter from A to whatever so I can sort them by alpha tag and get them bach in order.
