BCD325P2: Lost
jamaal0299
East Cleveland
#1
I fist manually programmed 155.1300 (East Cleveland, OH PD) which is a conventional analog frequency. After though I used software to program other freqencies, now the 155.1300 doesn't pick up and it's set as a priority. Please help!
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
#2
What software did you use? Did you put this frequency in a group, and set up a Group Quick Key? Did you allocate a system?
There's really not enough info here to help you out...
Mike
jamaal0299
East Cleveland
#5
I even reset scanner and only entered the one frequency, but have only heard it transmit a few times and then nothing. I have listen to this local frequency for years
#10
I haven't monitored 155.13 in a long time. The RRDB shows it's still East Cleveland PD but I personally couldn't tell you if they're still there.
