Hello, I'm thinking of getting the Grove Scanner Beam Antenna II (http://www.grove-ent.com/BEAMII.html). However, the specs say this antenna has no gain in the 30-50MHz range. Are there any good antennas around the same price range that have any gain in the 30-50MHz range? Is it really that important? Is it even possible? It will probably be the main frequency range I scan, and I'll be scanning areas at least 35 miles away, if not more. I'm just curious. I've read rave reviews about how far this antenna can receive, but I'm not sure if I should look for an antenna with gain on the 30-50MHz range.
