Anyone else have an issue with stock USB cable and Low USB Bus Voltage message? The only way to get rid of message is to disconnect cable. Sometimes reconnecting works for a while until you start interacting with ProScan. Checked voltage and was 4.0/3.9V.
Tried with option to charge while connected and not but doesn't seem to matter. The latter shouldn't care especially since it's only being used as serial connection. Used as mass storage earlier to try loading beta firmware and got the message. Eventually got it to work with disconnect/reconnect but quite annoying.
Posted the below and thought it was due to a 15' cable but isn't. Still have the same intermittent issue.
https://forums.radioreference.com/uniden-tavern/371618-anothermetoosds100.html#post2945363
