BCD996P2: Low Volume Level Compared To BCD996XT
Wrong
#1
On the new BCD996P2 I have the volume level is low compared to the BCD996XT that I have.
Volume control has to be set to 14 or 15 for the same volume that a 4 or 5 gives on the BCD996xt.
Is this normal for the P2?
Did I get a BAD P2?
JamesO
McLean, VA
#4
Did I get a BAD P2?
Are you using an external speaker or headphones?
Have you tired an external speaker or headphones?
The speaker could be defective, I purchased a BC785D new about 15 years ago and it had a defective speaker, I ran with an external speaker then replaced the internal speaker with a higher quality speaker and never had any problems after that.
