Lowell Fire Dept. Broadcast Host Feed
ham1guy
Tyngsborough, MA
#1
Hi everyone,
I have been the Exclusive Feed for the Lowell Fire Dept.,( Greater Lowell Area Fire ) (Only Transmitting Lowell Fire).
Today I have changed the location of my antenna and I am now able to receive a much larger area. So I have changed the feed to Transmit Lowell and Tyngsboro Fire and may include surrounding area Fire Department's such as Dracut, Chelmsford, Dunstable, Groton, etc, if incidents occur in those areas
If there is someone in the Lowell, MA area that can change there feed exclusively to Lowell Fire or if they have a friend or a family member that has a scanner and a computer to setup a feed, there would a be some appreciative people out there that would listen to the stream.
snowman3725
#2
Wirelessly posted (Mozilla/5.0 (iPhone; CPU iPhone OS 6_1_3 like Mac OS X) AppleWebKit/536.26 (KHTML, like Gecko) Version/6.0 Mobile/10B329 Safari/8536.25)
ham1guy said:
Hi everyone,
I've always wanted to get involved in something like this, I have a couple scanners I'm not using that I'd be glad to set up and broadcast LFD and Trinity operations. I'm from the area so reception is great. No idea on where to begin however.
W8RMH
Grove City, Ohio (A Bearcat not a Buckeye)
#3
snowman3725
#4
Application sent, fingers crossed!
snowman3725
#5
I'm proud to announce Lowell Fire and Trinity EMS IS UP AND RUNNING!
