LPE-200 EDacs radio
Forts
Ontario, Canada
As mentioned above, ProGrammer is your only option. Versions R20 was the last version released... R19 and R20 require a license key.
Forts
Ontario, Canada
Hello now on this LPE-200 Edacs radio the software is called programmer R20 or R19
Not sure what you are asking. There are many versions of Programmer. The most current is 20. As I mentioned above versions 19 and 20 require a license key from Harris, so you aren't going to find a working version of it in the wild.
ElroyJetson
Florida, where you wish you were!
Version 18 is probably the one you want. I can't tell you how to get it but 18 is the last version that can be installed without a license key and it supports every radio short of the latest ones that support P25 Phase II trunking.
jimbo1960
St.Louis MO
Hello everyone I been getting everything setup to see how'll it works to program the LPE-200 Two radio
I have everyhting but I need to know where I could get the software, can anyone help me with this is
there any software on ebay that I could use, I appreciate your help,
Thank You jimbo1960
jimbo1960
St.Louis MO
software
I need to know if anyone has a copy of the software programmer for the LPE-200 EDACS radio, have everything just need to get the software called programmer
GM
I purchased my ProGrammer Software from 49er Communications. It took about six weeks to get it, since it's a special order item directly from Harris Corp. :)
