LPE-200 encode
Newark, NJ
#1
I am looking for a way to program a number of older LPE-200s to tx an identifier on PTT (don't care if it's on key press or release). I've had the radios evaluated and there is no room for cimmaron encoding board.
Although these are EDACS radios, I need the identifier conventional.
Does anyone know of any way to get non-system radios to tx a DTMF sequence on key up or release?
The Cimarron displays in our dispatch are triple decode so DTMF, MDC1200, GSTAR I don't care which I'm just looking for a means of identifying the "children" in my agency without expensive investment. Thoughts and ideas are welcome either here or via e-mail at jtroisi@eccorrections.org
Thanks in advance.
Mason, MI
#2
Just wondering if you ever got an answer to that post? I also need to program some radios (p7100) with the ability to transmit an identifier in conventional mode. Not a lot of information out there on this.
Aaron
Muxlow
Middlesex County
#3
Ill try and program my Jaguar with DTMF and see if i can get that to transmit/decode on another radio.
Just looking at a LPE Scan pers file. I dont see a option to encode a MDC or a DTMF signal. There is a the box to decode but not encode.
In the next few days ill have a LPE here so ill test with that and the jaguar
