As AlabamaRS mentioned, if you want to monitor communications on Staley (Masury) or HTW (Girard), you're going to have to figure out the layout of the system because nobody else has.
1. The LCN order on those two systems is not verified.
That system was likely set up in the DB based upon FCC data (which does not indicate which LCNs are in use and what frequencies are assigned those LCNs).
2. The systems may or may not be active
3. If the systems are active, the may contain none (unlikely) of the listed frequencies, some (likely) of the listed frequencies, or all (maybe, maybe not) of the listed frequencies.
LTR syadmins notoriously use frequencies from various licenses that they have - They like to mix and match. Just because FCC data says there are x # of frequencies for a system, that doesn't mean all of those frequencies are in use and that doesn't mean that any or all of them are in use for that system. Yes, they should be - but in the real world, things aren't nearly as predictable with LTR systems.
HTW and Staleys all have a gazillion licenses for trunked frequencies around the Ohio/PA area. In addition, Staleys bought out a lot of other companies in the Ohio/PA area and "inherited" their frequencies as well.
So you may find that the systems use a combination of frequencies from many licenses, some which may not even be directly under their name at this time.
It's a hodgepodge mess... a challenge for sure.
If it were me, and I were really antsy about seeing if these systems were active, I'd do something like this (using the Staleys system as an example):
Program 5 LTR systems. In System #1, program the frequency listed as LCN1 for ALL 20 frequencies in that system. In System #2, program the frequency listed as LCN1 for ALL 20 frequencies in that system. Repeat for System #3, System #4, and System #5.
Make sure you set those systems for open mode / ID Search / group wildcard (nomenclature is different depending upon the type of scanner).
Then scan those systems for days or weeks. Make note when you hear traffic - WHen you hear traffic, look a the display - the display will show the TGID as well as the frequency and the LCN. Once you have confirmed that frequency xxx.xxxx has the LCN of #10 (as an example), you can then go into all five systems and program LCN 10 with that frequency.
Scan for days or weeks more. When you see a new LCN active, note the frequency displayed - then go through in all five systems and set that LCN to the frequency that you have verified. Eventually you narrow things down.
Keep in mind that LCNs don't have to be consecutive - Oftentimes there are wide spaces between LCNs in use on a small system (ex: 2, 5, 10, 13, 17 may be active, all others may be inactive). This is why you have to start populating all possible LCNs with a single frequency so that you can start to determine what LCN that frequency is really assigned.
Be the first to map out one of those systems! Submit your results [only verified/confirmed info] to the RRDB so that others can benefit.
Start a thread in the Ohio Forum asking for others in the area to help you attempt to tackle those two systems. You may get some collaboration. Unfortunately, I cannot hear up into Trumbull on UHF so i can't help you - i did what I could to verify the systems in Columbiana/Mahoning, counties for which I have spotty coverage.
Mike
