Ltr & Mot
Paragould/Greene County AR
#1
I have my pro 97 set up for LTR trunking in one bank, However I have another MOT system I just discovered that I have also set up besides the LTR system...Now, My question is Do I have to put them both in different banks or can I mix the LTR and MOT banks...BUT IF I program them in how do I save the ID's Like I do the LTR ID's.. Change the bank Name To MOT which would mean It'd have to be in a different bank then the LTR..Right?
loumaag
Silent Key - Aug 2014
Katy, TX
#2
You cannot have two different types of trunking in one bank. It is impossible, as you surmise; you must set the bank for the TRS type. Since you can only pick one...
It is possible to put conventional with the TRS and even multiple Motorola sites in one bank (indeed if you are doing LTR or EDACS and there is no overlap on LCNs (pretty rare), you can do it with them also).
