LTR Standard
SKYNET156
Duplicate account of Tom Sherman
Banned
Orange County, CA
Do you have t have a key to monitor LTR Standard via a LTR Radio? i have a LTR UHF Radio that i would like to monitor it with and i don't want to have to listen to the key ups every few seconds.
Any suggestions?
WayneH
Forums Veteran
Super Moderator
Sitting in an airport somewhere
No key is needed. Just setup the channel numbers (in some software versions you need to know the official FCC channel numbers so conversion is required), make sure the area bit is correct (if applicable) and enter in the group with its home channel. The group will only be the last three digits of what scanners use. So if it's like 1-12-089 then that means the Area Bit is 1, 12 is the home LCN and 089 is the group.
It's pretty easy once you understand where it goes in the software.
