LTR Trunking With Unknown TGID's
btritch
Paragould/Greene County AR
Anybody know how to monitor a UHF Trunking system if you don't know the TGID's.. I had it set up on my OLD kenwood but with this new one I'm not sure how do it, I can put in the system but how do I set it up where I hear all of the traffic across the system regardless of the ID.. This is because I don't know the ID's yet and want to monitor all of them.
I currently have a Kenwood 8180, Any input is helpful.. I've messed with it and not figured it out yet.
ramal121
Sonoma, CA
With the system set up and at least one GID entered (a dummy one is OK), go to zone edit and find "block IDs". In decode use 1 as start and 250 as end. This will cause the radio to unmute on any ID that shows up on that home channel. It will not follow those block IDs on trunk-off (any valid GIDs you have entered though will trunk normally), nor will it display anything different on the LCD. It's kinda like a monitor button for the home channel. If you want to listen another home channel you'll need to change that or make a new system. You can use the start/end range to narrow down certain IDs.
btritch
Got it. It's listed under Zone Edit. I was looking under GID edit..
Thanks For The Info.. I'll change it once they actually switch to that system, But it's a system in progress they're in the middle of changing over to and haven't completely yet, I wanted to monitor it till they got on it for good. I'll change it eventually but for now this way will work. Thank You..
btritch
What if I have 2 different home channels. Do I need to make one for each channel? I went in and put one like you stated above and I never hear a thing. But they could be on another home channel which is Why I ask if I need to put that setup in 3 times for 3 control channels.
ramal121
Sonoma, CA
Should work. Maybe what you tried is a "trunk to" channel and not a home channel for any ID. Possible that of all the system channels only one may be the home channel for all IDs. Yes you can make multiple channels of the same system and give each a different home channel and then scan them to look for the activity.
btritch
I'll have to check the settings and see about that..
