Are you suggesting putting the Central Virginia Radio Communications System into 3 different scan lists so that it scans it three times?
I also noticed that some frequency's in some cities are set to FM and Central Virginia is set to NFM. Should I set Central Virginia to FM in EZscan software?
Yes - in some cases.
Assuming "perfect" reception, your TRX is only going to find and remain on one of the three sites. Again, assuming perfect reception, it will ignore the other two even if they are in range.
By splitting the three sites into three systems, you can force the radio to try all three sites.
Of course, this might only make sense if you can receive more than one site --
I'd typically import the entire system into EZ Scan assigned to scanlist 1 and lock out all but one site.
Then, use the Duplicate button to make a second copy of the system. Lock out all but another site. Assign all objects to scanlist 2.
Then, use the Duplicate button to make a third copy of the system. Lock out all but the final site. Assign all objects to scanlist 3.
Then, toggle each scanlist on - but only one at a time - 1, 2, or 3.
Which one(s) find activity and/or show the radio is tracking the system ("T" on the display)?
If more than one, which seems to have better reception and/or more activity?
But keep in mind, the simulcast will still be a problem even using this method.
If you need help, let me know. I can send you a "CDAT" (configuration) to try.... you'd ten need to copy it into your TRX-1 folder and transfer it to your radio/SD card.
