LYT Q-18
#1
I can't find any reference to this radio anywhere. Does anyone have any info on it? I assume it is a clone of some other model.
#4
Is there any way to get chirp to query this unknown radio assuming I can assemble an appropriate data cord? The radio works with my ptt hand mic from my TH28A, so I know which lines those are. I voltage tested the pins I suspect are the data pins and they seem right. How do I get the radio to say hello?
#5
Apparently, without some deep hardware hacks (which have been done) one can only download and upload to these types of radios. During a preliminary search, I didn't turn up much as far as specific protocols for uploading and downloading. However, if it were me, I would start with the chirp mailing list. Undoubtedly someone on that list or a lot of someones know exactly the commands to send to the radio and the format of the data received back from it. I would start looking through the archives link on the following page:
chirp_users Info Page
If you find anything out, I would appreciate reading a post back here with a simple outline of the protocol.
ETA: I think there is a way to use chirp to get a dump from the radio but did not find exactly how to do that. Jim Unroe here on RR might know.
#6
My guess is that you send it a read command from a proper terminal or a homebrew program and it spits back a hexidecimal file memory dump. Likewise, I assume you send it a write command and then feed it a hexadecimal memory file. There is probably acknowledgement and other hand shake in there as well.
#7
I did some more digging. The radio was manufactured by "Le Yitong (Hong Kong) Limited" I found a listing for a company in Shenzhen and have sent them a query. We will see...
Ron
