M7100 Transmit/Scan issue
KG5HHS
D/FW
Hello Everyone,
I have a very odd problem. I have a VHF P25 M7100. I programmed a simplex channel with a DCS tone but it will not receive that channel and it will not transmit on that channel if the radio is in scan mode. I found this to be very odd. I have tested this by transmitting and receiving on many radio's. I can receive and transmit fine as long as the radio is not in scan mode. Does anyone know how to fix this?
kb4cvn
Silent Key
Nowhere near a paved road, away from the maddening
Hello Everyone,
In the Conventional Frequency Set:
Is the channel in the Scan List?
Under SCAN OPTIONS:
Is ALWAYS SCAN SELECTED CHANNEL enabled?
Is SCAN WITH CHANNEL GUARD enabled?
KG5HHS
D/FW
Yes, scan is selected for this channel in the conventional frequency set. Also under the Scan Options, "always scan selected channel" and "Scan with channel guard" are selected.
KG5HHS
D/FW
Im using Programmer R18B02
I usually just edit the file, save it and write it to the radio.
Revision is J2R11C02
DSP code I think is F8R06N05
KG5HHS
D/FW
I just checked, in Scan Options > Universal Scan Options >Transmit Select I have "Selected".
