M7100ip hand held control head help
kerrick
tx
Hello all ok here is my problem. I have a M7100ip VHF currently set up for system control head all working good. however now moving from a truck into a car and no room for the full control head. so decided to goto the HHCH when I plug control head into existing control cable my HHCH is dead doesn't light up or display anything I have reprogrammed radio with RPM 14C05 for the HHCH still nothing do I need to change out the control cable? can't figure out why its dead with HHCH. I have tried 2 separate HHCH in case 1 was bad. Switch back to system control head and all good.
n3obl
Ø
PA
I thought the HHCH requires a different control cable. Not sure though.
Mattsenft
Harrisburg, PA
To use a HHCH on the M7100 you will need the HHCH interface cable in addition to what you already have. CA101619V1 is the cable without a siren interface, CA101619V5 is the cable with the siren interface.
